MySQL server error report:Array ( [0] => Array ( [message] => MySQL Query Error ) [1] => Array ( [sql] => SELECT * FROM `sthifi_com`.`stx_bbs_type` WHERE cat_id= ) [2] => Array ( [error] => You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 ) [3] => Array ( [errno] => 1064 ) )
